18-12-2006, 09:57 AM
Pictures of the parts are necessary because there are lots of small differences between models. If you need silencers and tubes, you should think about replicas as it is cheaper than restoring them all yourself. Carburator covers should be the last things you need if you want to drive your IZ.
I suggest that you make pictures, take needed measurements, put list together, make calls to some motorcycle spare parts shop in Tallinn and come to collect your needed parts. Print out pictures and measurements and take them with you if you come to Estonia.
