18-11-2021, 15:27 PM
sellel lehel
https://www.vanguide.co.uk/mitsubishi-l200-problems
on selline viide
The Mitsubishi L200 heater matrix forms part of the vehicle’s cooling system; it reuses heat from the vehicle’s coolant to heat up the cab. However, it is known to fail quite early and leak, which results in the smell of anti-freeze working its way into the cab and the fogging of interior windows. Replacing the heater matrix is quite a difficult task due to its location, and we recommend having professionals to carry out this work if you’re not an expert.
kas on võimalik, et salongiradikas lekib aga ainult siis kui on kuum. ehk külmal ajal kui küte on intensiivsem siis kuskilt paisub "pragu" lahti ja minimaalselt udutab (selleks pole palju vaja ju klaasile)
ja soojemal ajal on "pragu" kinni ja probleemi ei esine.
vähe usutav muidugi aga mine tea
absorber seisval autol ja hooajalisel liikuril väga pro lahendus aga igapäeva auto peaks küll olema suuteline ise ventileerima ennast kuivaks.
on selline viide
