Millele võisid kuuluda need rattad?
Pildid:
http://i36.tinypic.com/2z3zbyo.jpg
http://i35.tinypic.com/21c5r0y.jpg
http://i34.tinypic.com/2uer4lh.jpg
http://i37.tinypic.com/2s5z0h0.jpg
http://i37.tinypic.com/rc7py9.jpg
http://i33.tinypic.com/dyw4js.jpg
http://i36.tinypic.com/10wt992.jpg
http://i34.tinypic.com/9g98bo.jpg
http://i34.tinypic.com/nxl6o1.jpg
Piltidel 1 ja 2 on tegu IZ350...IZ49 ratastega
Pildil nr 3 tundub olema Rudge ratas, täpset mudelit ei oska õelda.
Ehk siis:
Hi Veikko, this is a standard rear wheel from a 1937 to 1939 500cc. If the rim is 20" then it originally came from an Ulster - if 19" a Special or Sports Special. It is NOT an ISDT wheel which has 6 peg fitting rather than 3 pegs and 3 bolts as in this hub although the 3 pegs are missing - hope this helps
Tänan kõiki vastajaid abi eest.
Sidorov Kirjutas:Tänan kõiki vastajaid abi eest.
Mis nende ratastega plaanis on?
