Postitused: 2,447
Teemad: 54
Liitus: Jan 2008
28-12-2015, 01:40 AM
(Seda postitust muudeti viimati: 28-12-2015, 01:40 AM ja muutjaks oli
DevilDeVille.)
Mikistani jebaist leidsin ka sellise toreda asja:
Hea pimedatel talveõhtutel sirvida ja nuputada, et mis lisasid küll luksussportluukpärale tellima peaks.
Postitused: 2,447
Teemad: 54
Liitus: Jan 2008
Vänt läks lihvimisse. Kaelad solidaarselt viis sajandikku alla standardi, sestap saalendus ostetud esimene remont elik 0.25
Pildike kah, tehtud kartuliga, a mittepeegelpinnad on täiesti tuvastatavad:
Postitused: 2,447
Teemad: 54
Liitus: Jan 2008
03-01-2016, 12:24 PM
(Seda postitust muudeti viimati: 03-01-2016, 12:25 PM ja muutjaks oli
DevilDeVille.)
Postitused: 2,447
Teemad: 54
Liitus: Jan 2008
03-01-2016, 23:01 PM
(Seda postitust muudeti viimati: 03-01-2016, 23:42 PM ja muutjaks oli
DevilDeVille.)
Publikumile tutvumiseks ka naljaklapp kogu oma surmtõsiduses:
Plokikaane pildilt saab observeerida naljaklapi paiknemise kohta, kuhu alfistad kiiresti püüaksid oma topeltsädet ilmsesti istutada
Natuke netistleitud naljaklapijuttu kah:
G32B - 1.6L that uses the MCA JetValve system that Mitz used in their earlier engines, especially for the Dodge Colt/Plymouth Champ hatchbacks that came out in the early 80's.
Thus, if anyone hits one of these motors with ticky valves, the intake (along with the airjet valve) is .006" and the exhaust is .010" , using cold settings for proper adjustments with timing marks at TDC on the pulley (by using a 1/2" socket ratchet wrench end to turn the pulley quite easily..) for each set of four valves. You roll the crankshaft around 360 degrees for the other set of four valves.
The third valve was designated as, what's called the "AirJet" valve. On carburetted motors that had this 12v setup, the intake manifold had two runners and one runner desinated to this small valve the size of a ten-penny nail head.
The mixture assigned to this small valve was a rich mixture, whereas the regular valve received a much leaner mixture and when added together was to correct air to fuel ratio combined. The rich mixture would enter the same time as the lean mixture and would then swirl (as a tornado, or cyclone) around the lean mixture to create a more complete combustion. It was very effective when it came to economical purposes and actually did create more BHP since of the more complete combustion.
Postitused: 2,447
Teemad: 54
Liitus: Jan 2008
Sain täna klapperkambrikaane klaaskuulipritsist kätte, tulemus igati bueno ja küsitud 22.- juudirubla väärt. Sestap julgen soovitada:
http://www.phoenixmoto.com/teenused
Postitused: 2,447
Teemad: 54
Liitus: Jan 2008
08-01-2016, 14:14 PM
(Seda postitust muudeti viimati: 08-01-2016, 21:11 PM ja muutjaks oli
DevilDeVille.)
Siit siis ilmneb, et värviks võiks olla Sutsupitsu R73 "New Safari Red" mida tuisati erinevatele liikuritele selga aastatel 1982-1986. Eksnäis, kas keegi siin maanurgas säändset tooni ka segada veel suudab.
Samas teistest allikatest võiks arvata nimeks "Brite Safari Red", minevõtakinninüüd:
Taaskord saab edastada oma tänusõnad Devorile, purgist ise lenduminev värv kenasti segatud ja minu valduseski juba. Lisaks sai varutud jõulisele piigplokiga Moparile veel vileuued esituled ja nende sisse Osram Nightbreaker Unlimited pirnid. Eksnäis, kas näitavadki siis paremini, kui lihtlabased haššneljad või jõuab spordiauto ka nende valgusvihust ettesõita. Oma koha varuosakarbis leidis ka Termos-Taat ja tema kõrval kükitab 5w40 täissünt õli ja sellesama õli filtreerija. Tulenevalt saabuvast talverallist ja üldse elementaarsest viisakusest, haarasin ligi ühe itlerite tankiakuvabrikuprodukti, mille parameetriteks 60 Ah ja 540 külmaltkeerutamise amprit. Plussklemm paikneb vasakul.
Postitused: 1,258
Teemad: 24
Liitus: May 2006
Mesmoodi see otsmise silindri põlemiskamber nõnna puhtaks lutsutatud sai?
Postitused: 2,447
Teemad: 54
Liitus: Jan 2008
08-01-2016, 16:32 PM
(Seda postitust muudeti viimati: 08-01-2016, 23:48 PM ja muutjaks oli
DevilDeVille.)
Tänaseks on nad kõik sama nägu. A saamise liikumapanevaks jõuks ikka vanahea füüsiline vägivald.
Edit: Just astusin uksest sisse tükkis värskelt esimesse remontmõõtu jõudnud vänderdava võlliga.
Postitused: 2,447
Teemad: 54
Liitus: Jan 2008
Postitused: 655
Teemad: 25
Liitus: Jan 2013
Mis plekist vidin see keskmiste raamipukkide külge kinnitub?
Postitused: 2,447
Teemad: 54
Liitus: Jan 2008
Selle alajaotuse suunalt toimib karterituulutus, sestap jõudsime (omastarust) loogelisele järeldusele, et eesmärgiks on suurturismiauto sihtotstarbelise kasutuse korral takistada vändal liigselt õlinaadi lendupaisata. Ploki küljelt on vägevad liitmikud suisa piltideltki tuvastatavad.
Sutsupitsuvõõra inimloomana tunnistan, et isegi esimest korda kohtan säändset lahendust.
Postitused: 2,447
Teemad: 54
Liitus: Jan 2008
Niih, nüüd siis ilmnes, et TakeT on suutnud eraldada vale hammasrihmasatsi. 120 vajaliku hamba asemel 122 ja mingi jebanuutõi tasakaalustusvõlli mäng ka veel lisaks. Kodanik 90Deville sõnul pidi sobima vaid rihma laius. Hakkasin arvetelt näpuga järge ajama ja voilà - ongi antud 88-90 Kala-Anti komplekt, samas, kui ülejäänud pudi samal arvel on sobivasti 84-88. Eks saan siis minna letiäärde kenasti halisema peatselt.
Postitused: 2,447
Teemad: 54
Liitus: Jan 2008
TakeT-is käidud ja mõnigase leiutamise peale tuvastatud, et sobima peab Sutsupitsu 4G37 rihmasats, elik 1.8 liitriste eriti suurekubatuuriliste piigplokkide oma. Koodiks JAP-KDD-508A ja hambaid 120 nagu ettenähtud.
Postitused: 2,447
Teemad: 54
Liitus: Jan 2008
Allak on kõikvõimas ja harva, kui ta magab hetkel, kui mina plaane pean. Rihm sai nüüd küll õige aga pinguti ikka ei sobi, sestap läheb praegu kokku vanaga ja tellisin mikistanist uue. Kuna seal asjad mittemoonigi ei maksa, siis lisasin ka ühe rihma ja eesmise tihendisatsi. Koodid kah:
BECK/ARNLEY
0380125
CLOYES
B064
SEALED POWER
22232BT
Postitused: 2,447
Teemad: 54
Liitus: Jan 2008
Postitused: 2,133
Teemad: 140
Liitus: Apr 2005
Sellel putukal tundub ka olema Keihini karburaator nagu enamusel Jaapani autodest!?
