Täisversioon: MB 300CE 1988, sm. pelle
Tervitused kõigile siin AM foorumis. Lisaks siis esimese postina siia oma auto, ta pole ehk vanuselt veel uunikum aga minumeelest on selle aja mb kupeed juba nn "noored klassikud".
Mootor on siis 3.0 12V, 132kw/179,5hp@5700 rpm, 255nm@4400 rpm.
Käike tuleb vahetada käsitsi ehk 5'ne manuaal on.
Auto värv on valge ja sees on sinine nahk.
Ls on 222000km, mis isegi võib olla reaalne olla kuna auto on seisnud ja enne seda oli pere teine/kolmas auto ning ehk swenssonite maal pole see kerimine kah nii aktuaalne.
Andmeid väheke vin dekooderist kah.
VIN WDB124***
Model 300 CE
Chassis 124***
Engine 103983 10 025446
Transmission 717430 01 068137
Order 0 8 569 32414
Approx. year 1988
Lights BOSCH
Wiper BOSCH
Dealer Sweden (569)
Interior leather blue (272)
Paint
147 arctic white (T)
Options:
  • 211 automatic limited slip differential (ASD)
  • 236 special lamp switching - daytime running lamps, special light wiring for Norway and Sweden
  • 240 outside temperature indicator
  • 280 steering wheel (400 mm dia.) and gearshift lever in leather trim; on W202 390 mm dia.
  • 286 luggage nets on front seat backrests
  • 341 additional turn signal lamps
  • 406 single seat with orthopaedic front seat backrest, left and right
  • 430 headrests in the rear
  • 445 steering column, electrically adjustable, and airbag
  • 506 outside rear view mirror, left and right, heated (electrically adjustable on the right) (l.h.d.), outside rear view mirror, right, convex, taxi export version
  • 512 radio Becker Europa cassette Becker radio Europa cassette, full stereo, electronic LW/MW/USW
  • 524 paintcoat preservation
  • 531 automatic antenna
  • 543 sun visor with vanity mirror, illuminated, left and right
  • 551 anti-theft warning system
  • 570 folding armrest front w202/210 stowage box front with armrest, front folding armrest w202 - housing at front with armrest
  • 588 automatic climate control and electric window lifters (front and rear doors)
  • 597 heat-insulating glass, windshield, band filter
  • 603 headlamp wiper unit and oil for rear axle with limited-slip differential, in canisters and containers
  • 611 courtesy lamps for front and rear doors, with W124 also for central doors/W202 front doors only
  • 620 emission control system, vehicles with catalyst technique
  • 630 ECE warning triangle
  • 640 aluminium disc wheels with radial-ply tires
  • 673 high-capacity battery
  • 809 Change of year of model, last figure shows new model year
  • 812 rear-mounted loudspeaker
  • 825 additional parts for Sweden vehicle version
  • 873 seat heater for left and right front seats
Vigadest on niipalju:
Vasak el aken ei toimi.
Kliima ei toimi(kont tühi ja kardan et pump kah läbi).
ABS ei toimi (mingi andur läbi, pole jõudnud veel vaadata) ja sellega ka ASD praegu ei tööta.
Istmetel see 406 lisa töötab ja aegajalt ei tööta.
Tühikäigu regulaatorit oleks vaja.
Uksed on vajunud.
Keretöid tahaks(Plaanis millalgi kevadel, värv jääb samaks).
Kindlasti jäi veel midagi mainimata aga vast suuremosa asjadest sai mainitud. Plaanis on siis auto teha korda ja jätta org konditsiooni.
[Pilt: uusv%F5re.jpg]
Veel pilte: http://www.zone.ee/pelles/MB300CE/ (nendel veel vana iluvõrega).
