Rollerid - Printerisõbralik versioon
+- automoto.ee foorumid (
https://forum.automoto.ee)
+--- Teema: Rollerid (
/showthread.php?tid=1143)
Rollerid -
vjatka - 01-01-2003
need ühe rolleri tehnilised andmed... vaadake 1/4 miili aegu... haigelt ära tuunitud, link kah
http://www.italjetdragster.com/
ENGINE
Type: 1 Cylinder / 2 Stroke
Lubrication: Separate Mixer
Max. Power: 14.47 hp @ 7500 rpm (125cc)
19.41 hp @ 8000 rpm (180cc)
Ignition: CDI Electronic
Starter: Electric or Kickstart
Battery: 12V
TRANSMISSION
Clutch: Automatic Centrifuge
Final Drive: CVT / Automatic Continuous
SUSPENSION
Front: S.I.S. with Single Hydropneumatic Shock Absorber (Adjustable Spring)
Rear: Single Hydropneumatic Shock Absorber (Adjustable Spring)
BRAKES AND TYRES
Front: 175 mm Disc, 120/70 r11
Rear: 240 mm Disc, 130/60 r13, 140/60 r12 (50cc)
DIMENSIONS
Length: 1720mm (50cc), 1775mm (125/180cc)
Width: 680mm
Seat Height: 790mm
Weight: 97Kg (50cc), 107kg (125cc), 109kg (180cc)
Fuel Tank Capacity: 7 litres (50cc), 12 litres (125/180cc)
PERFORMANCE
0-60 mph: 8-10 secs (est) (180cc)
1/4 mile: 16-18 secs (est) (180cc)
