What oil type for the Pobeda M20 2.1 1956? - Printerisõbralik versioon
+--- Teema: What oil type for the Pobeda M20 2.1 1956? (/showthread.php?tid=13129)
What oil type for the Pobeda M20 2.1 1956? - Samb - 02-09-2005
I cant find any info about this.
And also: can it be driven on normal 95 octane gas or shoul i use some chemicals too?
RE: What oil type for the Pobeda M20 2.1 1956? - valdo - 02-09-2005
Only mineral type of oils (preferreably ordinary 10W40). Never use any synthetic or semi-synthetic olis. They\'ll leak so easily and do not operate in every places (Pobeda\'s engines oli channels aren\'t made so accurate and precise as for nowadays cars).
RE: What oil type for the Pobeda M20 2.1 1956? - Samb - 07-09-2005
Thanks again Valdo!
RE: What oil type for the Pobeda M20 2.1 1956? - pkuldsaar - 08-09-2005
About the gasoline- its more safe to drive with chemicals. It is called lead substitute. STP has one, also Neste but Valvoline took it off from its list.
RE: What oil type for the Pobeda M20 2.1 1956? - jurkman - 08-09-2005
Use Valvoline Maxlife oil.
RE: What oil type for the Pobeda M20 2.1 1956? - Samb - 26-06-2006
Thanks for all good ideas...
So i should use gasoline substitute for lead in the M20?
RE: What oil type for the Pobeda M20 2.1 1956? - valdo - 26-06-2006
Samb Kirjutas:So i should use gasoline substitute for lead in the M20?
I think it might be a good idea... although some experts think that the substitute is not obligatory. Personally I suppose that better to use it instead of not using. No one knows what might to happen with the valves...
RE: What oil type for the Pobeda M20 2.1 1956? - Samb - 29-06-2006
Oki, thanks!
