TVR Speed 12 - Printerisõbralik versioon
+- automoto.ee foorumid (
https://forum.automoto.ee)
+--- Foorum: Noorklassikute Aruteluala (
https://forum.automoto.ee/forumdisplay.php?fid=22)
+--- Teema: TVR Speed 12 (
/showthread.php?tid=3878)
TVR Speed 12 -
nasa13 - 08-12-2003
http://www.pistonheads.com/tvr/speed12.htm
Engine: 7730cc 90 degree V12
Steel block, aluminium heads, 4 valves per cylinder
Dry Sump
12.5:1 compression ratio
Power: 800 bhp at 8250 revs
Torque: 650 lbs/ft at 5750
Weight: 1000kg
Chassis: Space frame with integral rollover and side impact protection.
Brakes: Front - 378mm ventilated with 6 pot callipers
Rear - 273mm ventilated with 4 pot callipers
Wheels: Front - 11x18, 285/35 tyres
Rear - 13x18 345/35 tyres
Paras superbikedega võidu ajada!
nasa13 - 10-12-2003
http://www.ultimatecarpage.com/frame.mv?file=car.mv&num=799
General specifications
Country of origin Great Britain
Year of introduction 2001
Numbers built N/A
Body design N/A
Weight 1070 kg / 2358.9 lbs
Drivetrain
Engine 90º V12
Engine location Front, longitudinally mounted
Displacement 7.730 liter / 471.7 cu in
Valvetrain 4 valves/cylinder, DOHC
Fuel feed Fuel injection
Aspiration Naturally Aspirated
Gearbox 6 Speed Manual
Drive Rear wheel drive
Performance figures
Power 800 bhp / 596.8 kW @ 7250 rpm
BHP/Liter 103.5
Torque 881 Nm / 649.8 ft lbs @ 5750 rpm
Power to weight ratio 0.75 bhp/kg
Top Speed N/A
0-60 mph Acceleration 3.20 s
