Tuvastada: Boschi generaator (jagaja) väljavõttega? - Printerisõbralik versioon
+- automoto.ee foorumid (
https://forum.automoto.ee)
+-- Foorum: Varia (
+--- Teema: Tuvastada: Boschi generaator (jagaja) väljavõttega? (
/showthread.php?tid=67983)
Aspelund - 14-10-2026
Kes tuvastab, millisele liikurile võiks kuuluda pildil olev generaator? Eriliseks teeb imelik väljavõte (näiteks jagaja jaoks).
Rihmaratas ei pruugi olla algne.
RE: Tuvastada: Boschi generaator (jagaja) väljavõttega? -
andresp - 18-10-2026
Ai pakub:
This is a vintage Bosch DC dynamo (direct-current generator), made in Germany, probably from the pre-war period.
The two additional photographs reveal important identification markings:
- Manufacturer: BOSCH
- Country: Germany (Made in Germany)
- Type marking: Appears to read
(some characters are obscured by corrosion).
- Construction: Cylindrical DC generator with a belt pulley and an external mounting bracket.
It is likely from a German vehicle or engine installation, but the Bosch marking alone does not yet establish the exact car model.
Identified vehicle: Phänomen Granit 25 H
I found an exceptionally close, likely exact match in a historical technical specification.
The Phänomen Granit 25 H (1936–1939) used a Bosch generator listed as:
Kood:
RJVE 4. 90/12 . 1100RS 112
This matches the identifying sequence visible in your attachment.
![[Pilt: motomuseum-hostalek.cz&sz=32]](https://www.google.com/s2/favicons?domain=https://motomuseum-hostalek.cz&sz=32)
The generator is rated at 12 volts and 90 watts, roughly 7.5 amps at rated output.
Conclusion: Your generator is very likely a Bosch RJVE 4 fitted to a Phänomen Granit 25 H truck. The same generator family may have been used in other German vehicles, so the truck is a documented application rather than proof of its original vehicle.
The historical reference is available here:
Phänomen Granit 25 H technical specifications.
