About the electrical of M20
Hi!
Im wondering if the M20 -56 is Plus-grounded (plussa-maadotettu)?
I see on the battery cable that "+" is connected directly to the ground.
I.e, should the batteris positive "+" be connected to the ground or should the minus "-" be (as normal now adays)
Please someone check your car!
/Samb
Samb Kirjutas:Im wondering if the M20 -56 is Plus-grounded (plussa-maadotettu)?
All Pobedas (until the last car was produced in 1958) have always "+" grounded. Never "-" - it is typical for the newer cars.
Thanks and Hi again Valdo!
Ok, you see the only place i saw it on was the cable...
So the coil will be connected in the opposite way too?
+ will go to minus on the coil (i have a modern coil)?
/Samb
