03-10-2005, 10:36 AM
The above-mentioned problem is unfortunatelly true. If you use the front axle from GAZ-21 \"Volga\", then the original 16\" wheel disks will ALWAYS scrape the axle constructions as shown in the picture.
Possible solutions:
1) To make special 4-5 mm thin disk between brake drum and wheel. In the centre - big hole for hub, on the diameter - 5 small holes for wheel bolts.
2) To use Volga 15\" wheels (looks like a little bit different from Pobeda 16\" wheels).
3) To use some washers / middle plate between the hub and steer lever (there are 2 bolts). (To make a little modified steer lever is a little bit complicated.)
Possible solutions:
Asume Kesk-Eestis Väätsal Pikk 9, oleme septembris avatud L,P 11-18
