18-01-2013, 04:00 AM
Tere, üritasin endale sportlikust huvist selgeks teha, mida üks korralik, FIA Historic Regularity Rally reeglistikuga kooskõlas olev auto endast kujutab. Lappasin enda harimiseks kuulsat FIA Appendix K-d ja sattusin justkui natuke lõhkise küna ette. Kui mängida, et tegemeist on 1962. aasta või uuema autoga juhtub minu arusaamist mööda nii:
2.1.13.4
Eligible cars must satisfy the legal requirements for road use
in their countries of registration...
2.2.1 All racing cars competing in Appendix K events must comply with Article 5 (Safety) and Article 6 (Technical Regulations).
3.2 Dating periods are as follows:
F) 1/1/1962 to 31/12/1965 (from 1/1/1961 for single-seat and twoseat
racing cars and up to 31/12/1966 for Formula 2), excluding
Formula 3 and single engine-make Formulae.
5.13 Rollbars / rollcages
5.13.2 Requirements
(b) For cars of all other periods (Kõik perioodid, mis ei jää vahemikku A-E, ehk alates 1962. a.): An appropriate ROPS providing
adequate protection is obligatory. These structures must be built
according to the specifications set out in this article.
5.13.5 Specifications
© For T, CT, GT, GTS and GTP cars of period F up to and including period G2, a ROPS conforming to Appendix VI, A to which
must be added one diagonal bar between an intersection and
a mounting point, on the main hoop or between the rear struts,
as well as a maximum of two anti-intrusion bars on each side as
specified in Article 5.13.6 (b). Reinforcements made according to
the Drawings K-13 to K-37 of Appendix V are also allowed. The
minimum specification is a ROPS in conformity with Article 5.13.5 (f).
(f) A ROPS in conformity with drawing K-50 or, where this is not
possible and subject to approval by HMSC, in conformity with
drawing K-51. Lines in solid are mandatory, with a compulsory
diagonal (orientation optional) complying with Appendix VI
B 8.3.2.1.1 and compulsory door bar elements which may
alternatively be as Drawings K-15, K-16, K-17 or K-18. Other
elements shown in dotted lines are optional.
Joonis K-50 on nähtav lingil, lk. nr. 258:
http://www.fia.com/sites/default/files/r...eb_def.pdf
Ehk siis, auto peab olema tänavalegaalne riigis, kus ta arvel on, ning peab omama turvapuuri, mis on kajastatud joonisel K-50. Selline puur Eestis minu arusaamist mööda legaalne ei ole, seega, kas Eesti elanikele on FIA regulaarsusrallidel osalemine juriidiliselt ebakorrektne? Või läks mu mõttekäik kuskil väga lappama?
2.1.13.4
5.13.2 Requirements
