[poolita] Lambdaanduritega seonduv
#40
Väljavõte ühest väljamaa õppematerjalist:
The outside of the bulb is exposed to the hot gases in the exhaust while the inside of the bulb is vented internally through the sensor body to the outside atmosphere. Older style oxygen sensors actually have a small hole in the body shell so air can enter the sensor, but newer style O2 sensors "breathe" through their wire connectors and have no vent hole. It is hard to believe, but the tiny amount of space between the insulation and wire provides enough room for air to seep into the sensor (for this reason, grease should never be used on O2 sensor connectors because it can block the flow of air). Venting the sensor through the wires rather than with a hole in the body reduces the risk of dirt or water contamination that could foul the sensor from the inside and cause it to fail.
Jootmisega see paha, et kui sitasti teha, siis võib kogu krempli takistus muutuda ja soojendusahel hakkab pilpaid näitama juhtplokile, mis omakorda viib juba järgmiste probleemideni.
[poolita] Lambdaanduritega seonduv - Autor: Janka - 18-12-2017, 01:10 AM
RE: [poolita] Lambdaanduritega seonduv - Autor: Olaf - 13-01-2018, 23:57 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: edvard - 22-10-2019, 18:58 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: _rein_ - 22-10-2019, 19:25 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: edvard - 22-10-2019, 20:06 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: Walter - 22-10-2019, 20:07 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: edvard - 22-10-2019, 20:37 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: v6sa - 22-10-2019, 21:42 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: edvard - 22-10-2019, 22:12 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: edvard - 22-10-2019, 22:19 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: muska71 - 23-10-2019, 07:28 AM
RE: [poolita] Lambdaanduritega seonduv - Autor: hundu615 - 23-10-2019, 07:33 AM
RE: [poolita] Lambdaanduritega seonduv - Autor: ivoalaska - 23-10-2019, 08:54 AM
RE: [poolita] Lambdaanduritega seonduv - Autor: olli - 23-10-2019, 09:09 AM
RE: [poolita] Lambdaanduritega seonduv - Autor: edvard - 23-10-2019, 09:55 AM
RE: [poolita] Lambdaanduritega seonduv - Autor: ivoalaska - 23-10-2019, 10:23 AM
RE: [poolita] Lambdaanduritega seonduv - Autor: aavu - 23-10-2019, 11:03 AM
RE: [poolita] Lambdaanduritega seonduv - Autor: Dexter - 23-10-2019, 12:34 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: highway2hell - 23-10-2019, 12:59 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: hundu615 - 23-10-2019, 20:20 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: highway2hell - 24-10-2019, 07:53 AM
RE: [poolita] Lambdaanduritega seonduv - Autor: edvard - 24-10-2019, 12:42 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: muska71 - 24-10-2019, 14:18 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: v6sa - 24-10-2019, 16:27 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: sturmbannführer - 24-10-2019, 18:39 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: v6sa - 24-10-2019, 18:42 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: sturmbannführer - 24-10-2019, 20:33 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: Walter - 24-10-2019, 20:56 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: edvard - 31-10-2019, 11:59 AM
RE: [poolita] Lambdaanduritega seonduv - Autor: edvard - 08-11-2019, 14:14 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: Dexter - 08-11-2019, 18:21 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: v6sa - 11-11-2019, 17:02 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: 13piisab - 04-07-2023, 12:21 PM
RE: [poolita] Lambdaanduritega seonduv - Autor: siimik - 04-07-2023, 14:58 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: viplala - 18-12-2017, 01:53 AM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: Marko - 18-12-2017, 02:21 AM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: vanapagan - 18-12-2017, 07:18 AM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: Tegelane5 - 18-12-2017, 12:52 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: vanapagan - 18-12-2017, 13:13 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: rollfix - 18-12-2017, 21:04 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: ivoalaska - 18-12-2017, 21:32 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: veix__ - 18-12-2017, 22:09 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: ivoalaska - 18-12-2017, 22:39 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: janek555 - 18-12-2017, 23:14 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: viplala - 19-12-2017, 00:21 AM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: janek555 - 19-12-2017, 00:30 AM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: impreza - 19-12-2017, 00:53 AM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: viplala - 19-12-2017, 01:20 AM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: Marko - 19-12-2017, 02:05 AM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: janek555 - 19-12-2017, 02:09 AM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: viplala - 19-12-2017, 02:30 AM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: janek555 - 19-12-2017, 02:42 AM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: Janka - 19-12-2017, 05:26 AM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: taavi - 19-12-2017, 16:34 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: kolentin - 19-12-2017, 17:16 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: 41Degree - 20-12-2017, 09:07 AM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: stihl - 21-12-2017, 08:56 AM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: vanapagan - 21-12-2017, 09:08 AM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: TeeTL - 21-12-2017, 09:59 AM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: janek555 - 21-12-2017, 10:40 AM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: mega - 21-12-2017, 11:24 AM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: Raivo - 21-12-2017, 12:14 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: Walter - 21-12-2017, 12:20 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: janek555 - 21-12-2017, 13:07 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: Walter - 21-12-2017, 15:54 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: janek555 - 21-12-2017, 16:09 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: Walter - 21-12-2017, 16:17 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: aavu - 21-12-2017, 16:42 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: janek555 - 21-12-2017, 16:52 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: vanapagan - 21-12-2017, 17:22 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: Walter - 21-12-2017, 18:38 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: stihl - 21-12-2017, 18:54 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: ivoalaska - 21-12-2017, 21:44 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: ivoalaska - 21-12-2017, 22:30 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: janek555 - 21-12-2017, 22:52 PM
RE: Autoremondi hüvitus ebakvaliteetse varuosa töttu - Autor: tiitnato - 21-12-2017, 22:55 PM
