11-05-2022, 21:29 PM
(11-05-2022, 20:07 PM)rehepapp Kirjutas: Järsku oskab keegi aidata.Peaaegu sama
Kui suur on mootori peale installitud tehase hüdropump?
Mark on GP 0-30-3
Ei oska leida kuuglest. Tundub väike. Aga ehk jaguks rooli jaoks. Vöi oskab juhatada keegi, et kas on topeltpumpa saada sinna auku?
KUBOTA HYD PUMP
New, Kubota hydraulic pump model 44512-75100. 'GP036' stamped on the pump. Aluminum housing.
SPECIFICATIONS
- Disp. 0.22 cu. in. / rev. (3.6 cc)
- Pump Type Gear
- Rotation CW
- Mount 4 bolt on 2-1/2" centers w/ 2-1/4" dia. pilot
- Shaft 0.534" dia. w/ 0.25" wide tang
- Ports 3/8" NPT
- Size 3-3/8" x 3-1/4" x 3-3/4"
- Shpg. 4 lbs.
