11-02-2021, 23:37 PM
(Seda postitust muudeti viimati: 11-02-2021, 23:38 PM ja muutjaks oli markomate2017.)
Hi
I've been working on this van over the Winter.
Its a solid van but the radiator core support has corroded, they all do this!
It means the front drops by over 50mm, the front fenders bend and hit the doors and the cooling fan hits the fan cowling.
Here is the van before I started work.
![[Pilt: 5adMIfVl.jpg]](https://i.imgur.com/5adMIfVl.jpg)
This is how much the front has dropped
![[Pilt: yMagRiXl.jpg]](https://i.imgur.com/yMagRiXl.jpg)
It can only be repaired by removing the front core support and repairing or replacing.
Stripdown started
![[Pilt: 1oV31h9l.jpg]](https://i.imgur.com/1oV31h9l.jpg)
You have to drill out the spot welds to remove the panel
Panel removed
![[Pilt: V9mOdqQl.jpg]](https://i.imgur.com/V9mOdqQl.jpg)
This what it's supposed to look like!
![[Pilt: UoAshAGl.jpg?1]](https://i.imgur.com/UoAshAGl.jpg?1)
I tried a lot of places but I could not find a new or new/old panel, so I had to repair the old one.
Stripdown started
Panel removed
