(Seda postitust muudeti viimati: 21-02-2010, 23:20 PM ja muutjaks oli alesato.)
Hello everyone. I have seen that the double chain connecting the output of the crankshaft to the transmission clutch is attached only by one strand.
I guess this is wrong. They seem not aligned. How can I fix it?
If I have to pull the clutch, as I do?
It could be wrong clutch basket for this bike. As I can see the bike is an IZ. Clutch baskets are not interchangeable between Jupiters and Planetas, so the problem might be that you have installed wrong clutch basket there.
