31-03-2002, 11:09 AM
GAZ 3102 - ja uuemad (31011 ect.)
http://www.geocities.com/MotorCity/Speed...u_pgz.html
http://www.geocities.com/MotorCity/Speed...z3102.html
Nowadays you can buy Volga with all of following import motors: .....ja suurim:
Toyota 5VZ-FE: in-line 4, dohc 16, displacement 3,378 cc (bore 3.68\", stroke 3.23\"), CR 9.6:1, gasoline, multi-point fuel injection, power 178 hp @ 4,600 rpm, torque 223 ft.-lb. @ 3,600 rpm. Toyota\'s gearbox. Can be installed in GAZ-3102 only because of its larger motor compartment.
Seega lähtealuseks eelpoolnimetatud mootor annab üsna suure varu \"võimsama\" installimiseks. Ainult vist oli mingi auto vanuse piirang selleks - vist oli nõue, et min.10 aastat peab auto vana olema
3,378 cc + 20%= u. 4,0 liitrit
power 178 hp + 30%= u.240 Hj
Seega võimalusi edukamaks ehitamiseks on näiteks kuni 1992 a. väljalaske Volga 3102 omanikel. Positiivne uudis.
Eelpooltoodud oletuslikud tehnilised piirid lubaksid muuhulgas ka 3,8 liitrist kompressormootorit vahele tõsta - sellised mootorid liigutavad täitsa edukalt USA-s näiteks Volgast suuremaid Buick´e jms.
http://www.geocities.com/MotorCity/Speed...z3102y.jpg
JA VEEL:
http://members.rogers.com/sofronov/Cars/...otary.html
The GAZ-3102 Car (also known as the \"Volga\") was powered by the two rotor VAZ-411-01 engine. This car was also available with the 210hp 3 rotor VAZ-431 engine, supposedly used by the KGB. Production started in 1981, as it used the same VAZ-411-01 engine as the VAZ-21079 Car (see above). Length 4960mm, Width 1800mm, Height 1422mm, Weight (4 cyl version) 1850kg. The 4 cylinder engines used were the ZMZ-406 (2.3l, 150hp, 170 km/h top speed) or the ZMZ-402 (2.445l, 100hp, 147 km/h top speed)
Seega pandi tihtipeale väike 210 hj rootormootor KGB volgadele vahele, raskema V8 asemel :duh
![[Pilt: PG07_18B.JPG]](http://www.fortunecity.com/silverstone/stirling/236/RussianRotary/PG07_18B.JPG)
EDIT:
http://digilander.iol.it/cuoccimix/ENGLI...gaz).htm#2
There was some exemplar with the V8 engine taken from the \"Tchaika\" limousines, and even some exemplar with Wankel two-rotor engine (produced by Lada), with 210 hp. Probably, also others Wankel models were produced, with three rotors and 280 hp (!!). These types of Wankel models were used by the KGB patrols; tires and brakes were still old-type, with diagonal-structure and drums (not disks)! I think that the braking action begins in Moscow and finish in Vladivostok, at the extreme east, near the North America...
See mootor sobiks väga hästi nii mõnegi Volga kapoti alla
- Tðaika V8 mida on läbi aegade kasutatud (23, 24, 3102 jne) Volgade kiiremaks tegemisel:
http://www.autocollections.com/image/car...engine.jpg
See ongi see kuulus \"3102, mis 14 mootoriga\"
http://www.gaz.cz/historicky_vyrobek.php...obek=31011
3111
Küllalt uus mudel, mis esindab veidi ka ida-lääne autoehitust. Nimelt on selle modifikatsiooni disain pärit GAZ ja Venture Industries (USA) koostööst.
http://www.geocities.com/MotorCity/Speed...z3111.html
http://www.auto.r52.ru/model3111.php
FROM ice:
http://www.gaz.cz/vyrobek.php?path=osobni&vyrobek=3111l
and
http://www.gaz.cz/vyrobek.php?path=osobni&vyrobek=3111o
and
http://www.gaz.cz/clanek.php?id=skodaze
EDIT
sellest vihjest võib oletada 280 hj Volga versioonide reaalset olemasolu
.....Probably, also others Wankel models were produced, with three rotors and 280 hp (!!). These types of Wankel models were used by the KGB patrols.....
Selliste eest ikka naljalt ei põgenenud :keersilm
JA VEEL:
EDIT:
3111
FROM ice:
and
and
EDIT
