(09-05-2016, 08:55 AM)motamees Kirjutas: (08-05-2016, 15:57 PM)Feeliks_Jalgraud Kirjutas: ... nimelt just dekompressiooni puudumises....
Kas see on miski nali?
Dekompressioon ongi kompressiooni puudumine ja siis ei lähe mootor käima. Ei saagi minna, kuna puudub surve.
Sa otsid pendiksi stopperseibi. Ilmselt peaksid pöörduma autoelektriku poole. Äkki tal on mõni sobiv olemas. Poes pole sellist asja trehvanud.
nali vast ikka pole, kuna nendel mootoritel on automaatne dekompressiooni süsteem, et survetaktis üle jõuaks vedada... -vahel läheb see süsteem nahka ja siis ei käi starteri jõud enam üle..
-pendiksi stopperi loodan saada puiestee tänava värkstoast, kus neid mootoreid remonditakse
(edit. hui v noz, -det moroz... sealt ei saanud miskit)
Compression Release System
Some small engines incorporate a compression release system to decrease operator effort when pulling a rewind starter. A compression release system is a system that relieves excess pressure during the compression event by allowing a small amount of compressed gas to be released through the muffler or carburetor.
The compression release system lifts either the exhaust or the intake valve slightly off its seat during the compression event (this is why the piston is positioned past top dead center to about 1/4" down from the top of the cylinder when adjusting valve clearances). This releases pressure and reduces the force required to pull the starter rope or load on the starter motor. A compression release is used on most Briggs & Stratton engines and does not affect engine performance above engine starting rpm.
