Postitused: 3,457
Teemad: 24
Liitus: Dec 2002
Peab jällegi valikut kiitma.
Sight tähendab võõramaa keeles midagi nägemise, vaatepildiga seotut. See viitab otseselt selle auto silmipimestavale kaunidusele.
Millised on tulevikuplaanid? Hübriidauto tuunimiseks oleks kõige sobivam viis vist pisikese tuumareaktori paigaldamine pakiruumi.
Postitused: 303
Teemad: 11
Liitus: Dec 2005
Vaatasin samuti kuulutust kuid kuulasin mõistuse häält. Ootame huviga edasist käekäiku.
Postitused: 2,435
Teemad: 54
Liitus: Jan 2008
Sellele oleks viisakas mõne siibik taiperri tehnika vahele visata. Hea ost, isegi mingiaeg kaalutud seda.
Postitused: 3,540
Teemad: 112
Liitus: Jan 2003
08-01-2021, 19:23 PM
(Seda postitust muudeti viimati: 08-01-2021, 19:24 PM ja muutjaks oli
13piisab.)
palju õnne!
mitte ainult tehnika pole huvitav - see on 4m pikk ja 850kg kaaluv jäiga alumiiniumist ja plastikust kerega sporditegemise masin!
taiperri hobustega oleks muidugi veel sportlikum - kaalu ilmselt juurde ei tulekski.
https://en.wikipedia.org/wiki/Honda_Insight
Honda increased the vehicle's fuel efficiency using aluminum and plastic extensively to reduce the vehicle's weight. The basic structure is a new, lightweight aluminum monocoque, reinforced in key areas with aluminum extrusions joined at cast aluminum lugs.[19] Stamped aluminum panels are welded onto this structure to form an extremely light and rigid platform for the drivetrain and suspension. The Insight has a body weight less than half that of the contemporary Civic 3-door, with increased torsional rigidity by 38% and bending rigidity by 13%.[17] Honda built the Insight with aluminum front brake calipers and rear brake drums, and with a largely aluminum suspension, in addition to standard aluminum wheels; reducing the ratio of un-sprung to sprung weight as well as the total weight. The fuel tank is plastic; the engine mounts are aluminum; and the exhaust is a small, thin wall pipe.[18] Its compact spare is also aluminum. The Insight weighed 1,847 lb (838 kg) in manual transmission form without air conditioning, 1,878 lb (852 kg) with manual transmission and air conditioning, or 1,964 lb (891 kg) with CVT and air conditioning.
Insight has a coefficient of drag of 0.25. The absence of a rear seat allows the body to taper just behind the driver and the rear track is 110 mm (approximately 4.3 inches) narrower than the front track.
Postitused: 89
Teemad: 1
Liitus: Mar 2006
Akud ja elekter minema ning päris mootor asemele ning nalja saab kindlasti kõvasti, sest see auto ei kaalu mitte halligi.
Postitused: 71
Teemad: 3
Liitus: Jan 2020
Ratsima kindlasti ei hakka. Ma ei viitsi ehitada sellisel määral asju. Sellise auto hind kasvab ajas just kui ta on originaalne.
Autoscoudis on müüdav asi 12 000 euroga muideks (manuaalkastiga).
Postitused: 185
Teemad: 3
Liitus: Mar 2011
Vaikus - koguvad vist julgust, või "lakuvad haavu"!
Mulle meeldib eriti esimese tiivaääre "sälk"- see on nii lahe. Polaroid (energiattootev) katus sobiks talle.
WRC- meestel oleks ka mida ülevõtta. Sellise tagarattakattega saaks sujuvamalt tagaottsa kuskile valli (kaljusse- kivisse)
"toetada", lõhkumata kohe rehvi/velge ära.
Postitused: 71
Teemad: 3
Liitus: Jan 2020
Postitused: 307
Teemad: 3
Liitus: Jan 2015
Sellel peaks olema Honda IMA süsteem. Ainult bensiini peale saab ümber teha sedasi, kui on lisatud tavaline 12v generaator. Kui seda pole, siis peaks elektriosa töötama. Seda seetõttu, et HV elektrimootor laeb tavalist 12v akut ja kui HV ei tööta, saaksid sõita ainult senikaua, kui 12v akus vurtsu sees on.
Mul praegu töökoas hübriid Civic sees, millel HV süsteem vigane. Honda hübriidid selles osas head, et kui kõrgepinge poolel miskit saba annab, siis ainult bensuga saad liigelda, seniks kuni väikesest akust voolu jätkub. Toyotad ja teised levinud hübriidi jätavad teele.
Postitused: 1,454
Teemad: 41
Liitus: Jul 2003
Kas pilt petab või silm ei seleta õigesti või ongi tagasild kitsam kui esisild?
