25-08-2021, 16:41 PM
107CDC20, THOMAS AIR COMPRESSOR, 12V, 0.49 CFM, 35PSI MAX
12VDC Vacuum Pump or Compressor Thomas 107 Diaphragm 12 Volt DC - Brake Booster Please refer closely to all the photos before purchasing. Unused, tested and in excellent condition. These were removed from equipment never put into service. You will receive one like the one shown in the photos as we have several. Many use this pump as a brake booster. Model # 107CDC20-898, with vacuum adjustment valve & gauge 1.4 cfm, Stroke (SI / USCS) 5.1 mm / 0.2 IN 12 VDC, 8 Amp Pump is tested with a reading of 21 in. Hg. on a test gauge - which matched the installed gauge. Additional pump specifications: Medium Gas Operating Mode Pressure or Vacuum Product Family / Type Diaphragm Model Number 107CDC20 Voltage 12 DC Energy Supply DC Motor Type Permanent magnet Motor Protection Class A Pressure Flow Rate @ 0 pressure (SI / USCS) 39.66 l/min / 1.4 CFM Max. Pressure Continuous (SI / USCS) 2,4 bar / 35 PSI Max. Interim Pressure (SI / USCS) 2,4 bar / 35 PSI Vacuum Flow Rate @ 0 vacuum (SI / USCS) 39.66 l/min / 1.4 CFM Max. Vacuum Continuous (SI / USCS) -775.4 mbar / 22 IN.HG Max. Interim Vacuum (SI / USCS) -775.4 mbar / 22 IN.HG Ambient Temperature, min. (SI / USCS) 10 °C / 50 °F Ambient Temperature, max. (SI / USCS) 40 °C / 104 °F Motor Rating (SI / USCS) 74.6 W / 0.1 HP Speed 2970 rpm Weight (SI / USCS) 2 kg / 4.5 lbs Current Drawn 8.5 A This unit measures 4.25" x 6.5" on the bottom plate, 5" tall 7.5" long and the head is 4" wide.
