Palun tõlkige ära.Kiire!
the only problem is that a newer engine with rear mounted distributor will foul the fire wall. You can change to a front mounted distributor or bang/cut a hole in the firewall..
Miks need puud alati vale koha peal on?
olemas.closed.Wink
