08-12-2003, 14:11 PM
http://www.pistonheads.com/tvr/speed12.htm
Engine: 7730cc 90 degree V12
Steel block, aluminium heads, 4 valves per cylinder
Dry Sump
12.5:1 compression ratio
Power: 800 bhp at 8250 revs
Torque: 650 lbs/ft at 5750
Weight: 1000kg
Chassis: Space frame with integral rollover and side impact protection.
Brakes: Front - 378mm ventilated with 6 pot callipers
Rear - 273mm ventilated with 4 pot callipers
Wheels: Front - 11x18, 285/35 tyres
Rear - 13x18 345/35 tyres
Paras superbikedega võidu ajada!
Dry Sump
Weight: 1000kg
