14-03-2008, 12:38 PM
Tellisin endale vanaaegsetele autodele (1960-1980) mõeldud mootoriõli. Tarnija pakkus samas ka veel vanematele (1930-1960) autodele. Kas on keegi huvitatud? Üks toomine kõik...
Pakitud on üheliitristesse plekkanumatesse.
Õlist endast:
API: SB
Pean vastuse andma esmaspäeval. Hinda hetkel täpselt ei tea, kuid pakuti miskit 50-80 krooni ringis.
Õlist endast:
Tsitaat:ELF HTX RETRO 1 is a mineral lubricant especially conceived for engines made between 1930 and 1960.SAE 40
API: SB
Tsitaat: ELF HTX RETRO 1 meets the specific needs of collection cars from 1930 to 1960 owners. ELF HTX RETRO 1 allows the preservation of collection cars’ engines in the best conditions.
Engines made before 1960 are different from current ones, particularly concerning the used metallurgy. As a result lubricants have to be adapted to these particularities.
When used with former engines, current lubricants may lead to some problems such as oil leaks caused by the deterioration of rubber joints. These impurities make the efficiency of the lubricant decreasing what can lead to compression problems.
The formulations used in producing ELF HTX RETRO 1 suit the characteristics of engines made between 1930 and 1960. It makes engine’s lifetime longer.
