Tuvastada: Boschi generaator (jagaja) väljavõttega?
Kes tuvastab, millisele liikurile võiks kuuluda pildil olev generaator? Eriliseks teeb imelik väljavõte (näiteks jagaja jaoks).
Rihmaratas ei pruugi olla algne.
Pilt (pildid)
Ai pakub:
This is a vintage Bosch DC dynamo (direct-current generator), made in Germany, probably from the pre-war period.
The two additional photographs reveal important identification markings:
  • Manufacturer: BOSCH
  • Country: Germany (Made in Germany)
  • Type marking: Appears to read
    Kood:
    D-JVE 4 90/12-1100
    (some characters are obscured by corrosion).
  • Construction: Cylindrical DC generator with a belt pulley and an external mounting bracket.
It is likely from a German vehicle or engine installation, but the Bosch marking alone does not yet establish the exact car model.
Identified vehicle: Phänomen Granit 25 H
[Pilt: bwXtgMGbUscz_-Sn-3AxOt1DbeaWBt8plqTr0ef9...ose=inline]
I found an exceptionally close, likely exact match in a historical technical specification.
The Phänomen Granit 25 H (1936–1939) used a Bosch generator listed as:
Kood:
RJVE 4. 90/12 . 1100RS 112
This matches the identifying sequence visible in your attachment.
[Pilt: motomuseum-hostalek.cz&sz=32]
The generator is rated at 12 volts and 90 watts, roughly 7.5 amps at rated output.
Conclusion: Your generator is very likely a Bosch RJVE 4 fitted to a Phänomen Granit 25 H truck. The same generator family may have been used in other German vehicles, so the truck is a documented application rather than proof of its original vehicle.
The historical reference is available here: Phänomen Granit 25 H technical specifications.
