05-06-2003, 05:46 AM
Tsitaat:ELECTRO-SHIELD™ PATENTED RUST AND CORROSION INHIBITOR
* The best corrosion and rust protector you can buy!
* The only corrosion inhibitor you can transfer from one vehicle to the other
Stops rust before it starts! Kit helps stop rust-in and rust-out. Clear polymer sealant protects painted surfaces. Designed with integrated circuits and silicon chips, this electronic breakthrough monitors and responds to changes in humidity plus other factors that lead to corrosion and rust. No spray-on coating can do this. Spray rustproofing can leave many inaccessible areas untreated. ELECTRO-SHIELD™ installs easily and leaves no spot unprotected. Corrosion can form under spray-on coatings…impossible with ELECTRO-SHIELD™. And there\'s never a need for touch-ups, because ELECTRO-SHIELD™ uses vehicle\'s battery to provide protection year after year. Included clear paint sealant (with highly conductive polymers) enhances paint protection for one year (we recommend annual re-application). HOW IT WORKS. Salt and other pollutants combine with water and humidity to create a kind of diluted \"battery acid.\" When this \"acid\" comes in contact with metal, an electrical imbalance causes electrons to migrate from the \"anode\" portions of your car\'s metal parts to the \"cathode\" portions. Positive ions of metal are left behind to unite with negative oxygen ions to produce corrosion and rust. ELECTRO-SHIELD™ provides an artificial source of electrons to restore the electrical imbalance and slow corrosion. Also, it discharges electrons to build up on those areas where the protective coating (paint, etc.) has been damaged, thus interfering with the formation of rust. Includes 2 anodes, wiring harness, 2 oz. bottle of paint sealant, complete instructions and registration form.
http://www.jcwhitney.com/productnoitem.j...36&BQ=jcw2
maksab 99$
mida arvate?
