What oil type for the Pobeda M20 2.1 1956?
I cant find any info about this.
And also: can it be driven on normal 95 octane gas or shoul i use some chemicals too?
Only mineral type of oils (preferreably ordinary 10W40). Never use any synthetic or semi-synthetic olis. They\'ll leak so easily and do not operate in every places (Pobeda\'s engines oli channels aren\'t made so accurate and precise as for nowadays cars).
Thanks again Valdo!
About the gasoline- its more safe to drive with chemicals. It is called lead substitute. STP has one, also Neste but Valvoline took it off from its list.
Priit Kuldsaar
priit@made.ee
+372 510 9332
Use Valvoline Maxlife oil.
Thanks for all good ideas...
So i should use gasoline substitute for lead in the M20?
Samb Kirjutas:So i should use gasoline substitute for lead in the M20?
I think it might be a good idea... although some experts think that the substitute is not obligatory. Personally I suppose that better to use it instead of not using. No one knows what might to happen with the valves...
Oki, thanks!
