Tuvastada: Boschi generaator (jagaja) väljavõttega?
Kes tuvastab, millisele liikurile võiks kuuluda pildil olev generaator? Eriliseks teeb imelik väljavõte (näiteks jagaja jaoks).
Rihmaratas ei pruugi olla algne.
Pilt (pildid)
Ai pakub:
This is a vintage Bosch DC dynamo (direct-current generator), made in Germany, probably from the pre-war period.
The two additional photographs reveal important identification markings:
  • Manufacturer: BOSCH
  • Country: Germany (Made in Germany)
  • Type marking: Appears to read
    Kood:
    D-JVE 4 90/12-1100
    (some characters are obscured by corrosion).
  • Construction: Cylindrical DC generator with a belt pulley and an external mounting bracket.
It is likely from a German vehicle or engine installation, but the Bosch marking alone does not yet establish the exact car model.
Identified vehicle: Phänomen Granit 25 H
[Pilt: bwXtgMGbUscz_-Sn-3AxOt1DbeaWBt8plqTr0ef9...ose=inline]
I found an exceptionally close, likely exact match in a historical technical specification.
The Phänomen Granit 25 H (1936–1939) used a Bosch generator listed as:
Kood:
RJVE 4. 90/12 . 1100RS 112
This matches the identifying sequence visible in your attachment.
[Pilt: motomuseum-hostalek.cz&sz=32]
The generator is rated at 12 volts and 90 watts, roughly 7.5 amps at rated output.
Conclusion: Your generator is very likely a Bosch RJVE 4 fitted to a Phänomen Granit 25 H truck. The same generator family may have been used in other German vehicles, so the truck is a documented application rather than proof of its original vehicle.
The historical reference is available here: Phänomen Granit 25 H technical specifications.
Tänan!
See ta on. Phänomeni omanikele saadaval. Kontrollitud, töökorras.
A
A sa kirjuta seltsimeestele seal lingil asuvale ettevõtmisse. Äkki soovivad, oleks ju hea diil.. või teavad kes tahaks. Meite mail võib see sul vedelema jääda.
Kindlasti võiks ma ta piiri taha müüa, aga sobivaid jõuallikaid peaks meiegi kandis olema. Ma pigem jätaks ta siia.
